Warnings y Notices en error log Prestashop
Juan
 Juan
Tengo un error log en mi Prestashop 1.6.11 que crece día a día y debo borrar con cierta frecuencia.
No son errores, pero sí warnings y notices. ¿Es normal?
En el error log veo entradas como:
PHP Notice: Trying to get property of non-object in /home/doctorbelleza/public_html/cache/smarty/compile/ff/20/ce/ff20ce189fdce0bc4481ce65ab2870d7521058b8.file.blockwishlist_button.tpl.cache.php on line 35
PHP Notice: Undefined index: wishlist_products in /home/doctorbelleza/public_html/cache/smarty/compile/ff/20/ce/ff20ce189fdce0bc4481ce65ab2870d7521058b8.file.blockwishlist_button.tpl.cache.php on line 35
PHP Notice: Undefined index: thumbSize in /home/doctorbelleza/public_html/cache/smarty/compile/1a/6c/9d/1a6c9de016330446fc82b619abb3ef4c41eb3640.file.ovicpagebanner.tpl.cache.php on line 64
PHP Notice: Trying to get property of non-object in /home/doctorbelleza/public_html/cache/smarty/compile/1a/6c/9d/1a6c9de016330446fc82b619abb3ef4c41eb3640.file.ovicpagebanner.tpl.cache.php on line 64
PHP Notice: Undefined index: thumbSize in /home/doctorbelleza/public_html/cache/smarty/compile/1a/6c/9d/1a6c9de016330446fc82b619abb3ef4c41eb3640.file.ovicpagebanner.tpl.cache.php on line 65
PHP Notice: Trying to get property of non-object in /home/doctorbelleza/public_html/cache/smarty/compile/1a/6c/9d/1a6c9de016330446fc82b619abb3ef4c41eb3640.file.ovicpagebanner.tpl.cache.php on line 65
PHP Notice: Trying to get property of non-object in /home/doctorbelleza/public_html/cache/smarty/compile/ff/20/ce/ff20ce189fdce0bc4481ce65ab2870d7521058b8.file.blockwishlist_button.tpl.php on line 35
PHP Notice: Undefined index: id_product_comment_form in /home/doctorbelleza/public_html/cache/smarty/compile/91/de/2b/91de2b34453b4513f2cdf5fadf165169e45f7ef6.file.productcomments_reviews.tpl.cache.php on line 31
PHP Notice: Trying to get property of non-object in /home/doctorbelleza/public_html/cache/smarty/compile/91/de/2b/91de2b34453b4513f2cdf5fadf165169e45f7ef6.file.productcomments_reviews.tpl.cache.php on line 31
PHP Notice: Undefined index: id_product_comment_form in /home/doctorbelleza/public_html/cache/smarty/compile/91/de/2b/91de2b34453b4513f2cdf5fadf165169e45f7ef6.file.productcomments_reviews.tpl.cache.php on line 32
PHP Notice: Trying to get property of non-object in /home/doctorbelleza/public_html/cache/smarty/compile/91/de/2b/91de2b34453b4513f2cdf5fadf165169e45f7ef6.file.productcomments_reviews.tpl.cache.php on line 32
¿Alguna idea?
Saludos,
Juan
Respondido : 19/04/2018 1:45 pm
Hola juan.
prueba a desactivar los avisos de prestashop.
.- accede Parámetros avanzados -> Rendimiento
.- En el apartado de MODO DEPURACIÓN revisa que tengas las opciones como NO
Una vez comprobado eso, accede a tu cuenta de cPanel -> Administrador de archivos
.- accede a la carpeta cache -> smarty -> compile y elimina los archivo que tienes dentro de esa careta.
Respondido : 19/04/2018 2:43 pm
Juan
 Juan
Hola Pepe,
Gracias por tu respuesta.
He hecho lo que indicas, pero veo que el error log, que eliminé justo después de borrar los archivos que me indicas, sigue llenándose de entradas.
¿Alguna otra sugerencia?
Gracias de antemano,
Juan
Respondido : 19/04/2018 2:59 pm
Por lo que parece es un problema con tu theme, revisa si tienes actualizaciones de tu theme, es posible que no este adecuado para versiones recientes de PHP
Veo que el mensaje esta relacionado con el modulo de wishlist, si sigues con problemas prodrías buscar en lso archivos de tu theme la carpeta modules/blockwishlist y probar renombrarlo, posiblemente pierdas un poco el diseño del módulo pero es para aislar si este es el problema
Respondido : 19/04/2018 6:22 pm
